585,749 active members*
3,709 visitors online*
IndustryArena Forum > CNC Electronics > Dmm Technology > LinuxCnc "Step Time" "Step Space" "Direction Hold" "Direction Setup" values??
Results 1 to 6 of 6
    Oct 2006
    84
    What values are you folks using, and where did you get them?
    I've searched and searched and wasn't able to find the setting anywhere on various forums.
    Scott
    Dec 2007
    341
    Hi Scott if you find out I am at the same point you are, just setting up Lenoxcnc I can not find this out either been looking all over the other question I have is what step angle ?8 or is it some other thing! .
    If I find anything out I will post it here for you.
    Oct 2006
    84
    Woffler,
    Do you actually have the DMM hardware in your possession?
    not sure what you mean by "step angle". I did run across some settings that someone was using.
    I never got a response for my last email or two from the DMM people so I started to look elsewhere for some more rugged industrial drives and have been collecting Yaskawa and Mitsubishi motors and drivers.
    I pieced together the equivalent of a 3 axis 400W mitsubishi system for roughly half the cost of the DMM system minus the BoB.
    Dec 2007
    341
    Yes I have had them up and running on a mill and a lathe for over 3 years now running Mach 3 ,I am only converting the lathe to Linux cnc because Mach's lathe program is so bad and is constantly messing up.
    And I want to add a encoder to the spindle for threading as Mach looses it's fricken mind all the time! and ruins parts you never know what or when your about to get screwed by it.
    15362
    woffler
    The Step Angle with the drive electronic gearing set at 500 is .18 the Duration Time is 2 micro sec, hope this gets you going with your new control
    Mactec54
    Dec 2007
    341
    Thank's Mactec 54 that is what i need i should be able to get going from here ,and Scott to .
  1. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  2. Replies: 2
    Last Post: 11-16-2012, 03:17 AM
  3. Can someone explain "Full step", "Half step", "Quater step", etc. ???
    By danmst3k in forum DIY CNC Router Table Machines
    Last Post: 12-04-2008, 06:13 PM
