603,935 active members*
4,528 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Motor moves one direction using mach 3
Hybrid View
icncsigns Motor moves one direction... 12-28-2013, 04:57 PM
xjdubber If so you are missing your... 12-28-2013, 06:09 PM
Khalid in addition also check wether... 12-29-2013, 06:25 AM
MitchP I recently had the same... 12-29-2013, 11:47 AM
icncsigns Thanks to all,I will check it... 12-29-2013, 03:01 PM
    May 2010
    No matter which direction button is pushed motor moves only one way to the right.
    Jan 2007
    599
    If so you are missing your direction signal.
    Apr 2006
    3498
    in addition also check wether you have swaped mistakenly dir step wiring
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    Dec 2012
    18
    I recently had the same problem when testing my controller. One of the wires running from the BOB to the driver didn't have the 5+vdc current running through it it was suppose to. I replaced it & the problem went a way. I found it with my multi-meter.
    May 2010
    Thanks to all,I will check it out.
  1. motor direction in Mach 3
    By sndpntlynch in forum Machines running Mach Software
    Last Post: 01-01-2024, 05:54 AM
  2. Axis moves in same direction
    By mreitt in forum Mach Software (ArtSoft software)
    Last Post: 09-28-2013, 01:32 PM
  3. mach 3 slave motor(stepper) turns only one direction??
    By xkadet in forum Machines running Mach Software
    Last Post: 01-03-2013, 09:59 PM
  4. motor moves one direction: what am I missing?
    By boyvox in forum Stepper Motors / Drives
    Last Post: 10-11-2005, 12:43 AM
  5. Motor only moves one direction
    By spoiledbrat in forum Mach Software (ArtSoft software)
    Last Post: 06-12-2005, 07:02 PM
