586,103 active members*
3,359 visitors online*
    37
    Milling a PCB
    I am not sure if this is the right place for this or not, but here goes anyway. I would like to be able to mill a small pcb using Turbocad. Can anyone out there tell me the steps I need to go through to generate the required G-Code. I have designed the circuit in Eagle software, but am at a loss as where to go from there. Thanks in advance
    Ayjay
    Feb 2004
    2337
    Jun 2005
    52
    Quote Originally Posted by Ayjay
    Ayjay
    There is a wonderfull ulp that can be added to Eagle called pcb-gcode.ulp made by John Johnson. Look at his Yahoo group at http://groupyahoo.com/group/pcb-gcode/
    This ulp can make the Gcode file from the .brd Eagle file who can be used in several CNC programs. I work with TurboCNC with verry good results.
    AbSat.
    ps. ynneb is using the same ulp I see and points to a verry good introduction.
    37
    Thanks ynneb for the link - very informative. I downloaded and installed the files but when i tried to run it I got the folowing error message:
    can't open '/temp/tempdrill.xxx'
    No such file or directory
    Can anyone out there tell me what I am doing wrong?
    Thanks in advance
    Ayjay
