586,103 active members*
3,400 visitors online*
Results 1 to 13 of 13
    Jan 2014
    5
    Bridgeport Interact 720
    New to this site. my company has bought a Bridgeport interact 720 with a Heidenhain TNC 151 controller. When we power up the machine it goes through a memory check and the says power interruption I clear that but get a fault ( axis 4 meas. system defective a ) this is a 3 axis machine how wiil be able to clear this fault. Thanks.
    Jan 2014
    5
    After doing some checking the controller is actually a Heidenhaim 351 B.
    Nov 2004
    3028
    Try a PM to Gus. he has a bunch of these machines.
    I know that under the MOD key is where you can turn the 4th On or OFF, select display size, type of communications, access parameters etc.
    But I need to be in front of a machine and write down what I do instinctively.
    George
    Jan 2014
    5
    Thanks George
    1121
    I think you have a parameter mis set needs to have 4th axis disabled
    Jan 2014
    5
    That's what we are thinking. Just found out they the company we bought this from was using a rotary table so the 4Th axis was in use. We are trying to locate a parameter list for this machine also a programing manual for the controller. Can't seem to find how to get into the main parameters.
    1121
    code 95148
    just like all the controls
    there are manuals on the heidenhain website that should tell you which parameters are which
    Jan 2014
    5
    Thanks very much Gus
    Apr 2005
    37
    After the machine has powered up-
    press the MOD key and cursor up to "user parameters"
    Press enter-
    cursor up to "XYZ=0 XYZB=8"
    Press "0" to turn off the forth axis
    Press enter
    Press "end block"
    May 2004
    402
    DELETED
    other had answered
    Andrew Mawson
    East Sussex, UK
    Jun 2011
    61
    Re: Bridgeport Interact 720
    Quote Originally Posted by Daninwyoming View Post
    Press enter-
    Press enter
    Press "end block"
    And the other way round what do I do to get the 4th axis on my Interact please ? Hope you can help
    Jun 2011
    61
    Hi Monte , did you get an answer to your problem ? Im looking for the parameters toi put in my Heidehain to use the 4th axis ! Any help would be great , thank you Harry
    Jun 2011
    61
    Hi Gus , I hope you can help me , Im looking for the parameter to install the 4th axis ,can you help ? I hope so , thank you Harry
  1. Bridgeport Interact 412
    By Gncc50 in forum Bridgeport / Hardinge Mills
    Last Post: 07-22-2019, 04:32 AM
  2. bridgeport interact 520
    By goodmancncgcode in forum Bridgeport / Hardinge Mills
    Last Post: 04-03-2013, 02:53 AM
  3. Bridgeport Interact 1 MK 2
    By tommo61 in forum Bridgeport / Hardinge Mills
    Last Post: 12-23-2011, 04:34 PM
  4. Bridgeport interact 412
    By la1508 in forum Want To Buy...Need help!
    Last Post: 07-09-2010, 10:52 PM
  5. Interact 308 Bridgeport ?/:????
    By SGARCIAM in forum Bridgeport / Hardinge Mills
    Last Post: 08-21-2008, 10:22 PM
