587,299 active members*
3,598 visitors online*
Results 1 to 10 of 10
    Jun 2007
    43
    g0704 wiring pictures
    I was trying to get a project finished, so I think I pushed at little too far. The mill powered off, and after a few minutes, I turned her back on, and she ran again for awhile. Then she blew the fuse. When taking off the back panel, I must have let the cord pull too hard, as the white cord from the power line was unplugged. There are a few places that are able to be plugged in, but neither match up with the grizzly wiring diagram I've found. I'm hoping someone else out there might have taken pictures of there wiring. One change I noticed, is that on mine the white wire goes to the power board, however on some, the white wire goes to the fuse.
    Mar 2013
    116
    Here it is. The up to date one. The white wire which is Com. goes to the lug marked B on the ckt board that is mounted to side of the control box.
    CH
    Jun 2007
    43
    Perfect! Thats what I needed, THanks COMachineist
    Jun 2007
    43
    Bummer, now that I've got it plugged back in correctly. As soon as I hit the power button, the fuse blows. I must have fried something pushing too hard.
    Jun 2007
    43
    I'm in need of more help. I was able to get everything wired back up, and the fuse kept popping. I was able to find a good deal on a kbmm-125, so I installed it today, hoping there might be a short in the old controller. No such luck. Everything powers on, as long as I keep the RPM's at 0 everything is fine. Once I start turning the dial up, as soon as it is between 50-100 rpm's the fuse pops. It sounds like the motor is probably drawing too much in order to get it spinning. Am I looking at a motor replacement? Or is there anything in the motor I can check?
    Mar 2013
    116
    kuyote
    Sounds like you have a bad power supply board. That is the one on the side of the electronic box. I have replaced two of those on my G0704 one of those was a bad quality board that had some parts that never got soldered at the factory. Chinese electronics are the lowest quality I have ever seen. That is why I'm putting a Japanese VFD and 3ph motor on mine as soon as I get time. I already have The VFD and doing some research on motors now. Messing around with Treadmill motors and Chinese DC motors is a no win if you want reliability, and power.
    If it is under warranty you can get one from Grizzly.
    Good luck
    CH
    Jun 2007
    43
ID:	219116I know it's not the way to test capacitors, however the 2 ceramic capacitors on the power supply board show infinite resistance. I'm thinking I can replace these and be back in business. Does anyone have their board out that can ohm test them, and verify they have a connection between the posts?
    Feb 2006
    7063
    Ceramic capacitors will ALWAYS measure infinite resistance.... That is a meaningless test.
    Regards,
    Ray L.
    Jun 2007
    43
    Thanks Ray, that's what I was afraid of.
    I decided to try a treadmill motor to see if my motor could be the problem. I've hooked the treadmill motor up, and when turn the rpm dial up the motor starts to spin, and then stops. If I get the potentiometer to a certain position, the dc motor will turn on for a few seconds, and then shut off, for a few seconds. This will keep repeating. I've swapped the control board for a kbmm-125, and the motor, so the last thing I can replace is the power controller. The kbmm-125 was a used model on Ebay, so it's possible that a jumper or trim might need to be adjusted.
    Jun 2007
    43
    I was able to find my answer to the treadmill motor problem. If there is no load, it will turn off for about 10 seconds. Even resting my thumb on it is enough to add a load to keep it spinning. Now to build a motor mount. No time like the present to put on the belt drive as well.
  1. SX2/SC2 LMS Spindle Control Board Wiring (with pictures)
    By Nine8Six in forum Benchtop Machines
    Last Post: 08-24-2012, 05:38 PM
  2. G0704 wiring, inside the box
    By lcvette in forum Benchtop Machines
    Last Post: 02-25-2012, 12:49 AM
  3. Electronics Enclosure pictures/wiring and fusing
    By ahaidet in forum Benchtop Machines
    Last Post: 11-16-2011, 02:52 PM
  4. Need help wiring motor to driver and controller - pictures included
    By ltovey in forum DIY CNC Router Table Machines
    Last Post: 06-09-2011, 08:53 AM
  5. G0704 CONTROL WIRING
    By macatoms in forum Benchtop Machines
    Last Post: 03-09-2011, 10:23 PM
