586,080 active members*
3,485 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Bit Profiles That Don't Quite Match
    Oct 2009
    75
    I have a bit, that doesn't exactly match the available bits in DeskProto for milling.
    For example, I have a this bit:
    1/32" Dia x 1" Cut Height x 6.2º Tapered Angle Ball Nose Tip x 1/4 Shank ZrN Coated 3-Flute Solid Carbide 2D and 3D Carving Router Bit
    The closest bit in the menu is a "Ball nose, radius 0.4 = diameter 0.8 mm"
    Can you add bits, or adjust existing ones with settings?
    Greg
    Aug 2012
    181
    Yes, you can add cutters. As long as they are one of the supported shapes. Look through the menus. (no idea how the menu I'd called in your language)
    Gesendet von meinem Galaxy Nexus mit Tapatalk
    Oct 2009
    75
    Haben Sie vielen Dank!
    Your English is much better than my internet-assisted Deutsch!
    I was able to find the menu item and copy/edit a bit. The DeskProto "Help" was helpful when I wanted to know what the "free length" was.
    Greg
  1. How do I cut t-slot profiles?
    By Yello in forum T-Slot CNC building
    Last Post: 05-14-2012, 09:13 PM
  2. Profiles/Pocketing
    By Magnum164 in forum Visual Mill
    Last Post: 10-17-2011, 12:55 PM
  3. Mach3 Profiles
    By Drools in forum Mach Software (ArtSoft software)
    Last Post: 09-11-2009, 02:00 AM
  4. Z-Profiles
    By mrcodewiz in forum Dolphin CAD/CAM
    Last Post: 05-17-2008, 01:22 AM
  5. Rail profiles?
    By sp1nm0nkey in forum Linear and Rotary Motion
    Last Post: 02-04-2008, 07:11 PM
