Our company recently purchased a 99 model Trumph laser that was upgraded in 03 to 4000 watt. We have had minimal training and its killing us. Can anyone tell me if there is a starting point for the focus? We are running 12mm mild steel on tech table ST050O40. It is cutting but the slag on the bottom keeps the piece together. using 1.4 nozzle and 7.5 head. We have no manuals on focus adjustment and when we try the focus test we have a problem keeping nitrogen pressure. Also we were not told but if you do run the focus test do you run it on the same thickness material that you plan to cut? The cut we are producing is not a nice clean cut what so ever.Any help is appreciated and I know these are probably stupid questions but all I have ever run is a water jet and this is a totally different beast.I thought that once the program was wrote and put in it would run with minor adjustments.
