Decided to implement soft limits on a new build. Programs made with Cut2D won't start when I have soft limits enabled I get a "softlimit warning...continue? yes/no dialog box with a message of Soft warning on Z max in the display box.
soft limits:
X max 48 min 0 home neg enable
Y max 28 min 0 home neg enable
Z max 0 min -4 home neg disabled
no mechanical limits yet on all axes.
Cut2d Z 0 is set to bottom of material, thickness .75 and rapid is set to 1 This set Z home position to 1.75 in Cut2D which I thought is weird.
Without the soft limits enabled program works
I'd sure appreciate any advice
