587,610 active members*
3,535 visitors online*
Thread: soft limits?
Results 1 to 5 of 5
Hybrid View
    Jan 2011
    42
    soft limits?
    How do i set up soft limits in mach3 and can i set a home without switches? if so how do i do both of these?
    Mar 2003
    35538
    You can home without home switches, just click Ref All button, and it will set your home position wherever the machine is at that time.
    Before I had home switches, I would jog my machine against it's hard stops, and Ref All there, so I had a repeatable home position.
    Softlimits positions are set in Config > Homing/Limits, and toggled on and off with the Softlimits button on the run screen.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    I try to send all 3 axis home before I close the program, but in the event I need to home from scratch I do the following....
    Manually move each axis to it's hard stop
    Start Mach3 and the controller
    Set the jog mode to step and .1000 for stepping distance
    Now I jog each axis twice and this will set it off the hard stops by .2
    Then close and restart Mach3 and Ref All
    Jan 2011
    42
    so how do i input the data into the soft limits? Do i just input where i dont want it to go past or do i jog it over and set it?
    Mar 2003
    35538
    Just type in the numbers
    Gerry
  1. Mach 3, Soft Limits
    By Droider in forum Mach Software (ArtSoft software)
    Last Post: 02-11-2015, 07:34 PM
  2. Okuma soft limits
    By Carlton Jenkins in forum Okuma
    Last Post: 08-22-2012, 05:18 PM
  3. VF-4 Zaxis soft limits
    By Sam Mcquern in forum Haas Mills
    Last Post: 01-21-2009, 02:25 AM
  4. soft limits
    By zimba43 in forum Mach Mill
    Last Post: 04-01-2008, 10:18 PM
  5. Question about Soft Limits???
    By Dennis Fletcher in forum Mach Software (ArtSoft software)
    Last Post: 07-31-2005, 07:07 PM
