603,800 active members*
3,864 visitors online*
    Jan 2014
    34
    How do I optimize the use of tabs?
    I've been cutting 3/16" acrylic letters ranging from 4" to 12" tall and using tabs to keep the pieces from coming loose.
    I noticed however some times the tabs break, damaging the letters and/or cause piece to come lose and ruin the exit point.
    What thickness do you recommend the tabs be and how thick? Also is there any suggestions for optimal placement?
    I am using about 3-4 tabs per letter, generally one near the lead in and just 2-3 around the letter.
    Using a 1/4" single o-flute up cut, 12000 RPM and 40 ipm. Cutting using a single pass with tab length of 1/4" and tab depth of 1/16".
    Id appreciate any advice. Thanks in advance.
    Aug 2011
    1000
    Did you try double sided carpet tape (with fabric reinforcement) instead of the tabs? Your letters should be big enough to hold on that and removing the tape is probably much cleaner and easier than sanding of the tab remnants. The cut may also come out better without the bit going over the hump.
    Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
    Jan 2014
    34
    Hey Jerry, I've tried double sided carpet tape and it works well. I mainly use the tape for smaller more detailed cuts. The reason I am trying to utilize tabs is to reduce the additional expense of the tape and labor in applying and removing it. Currently I use a chisel and rubber hammer to remove the tabs which has worked well. I use a laminate trimmer tool when necessary.
    Jul 2007
    265
    Carpet tape works great for me as well. I use acrylic with protective film on both sides, and when I remove the protective film after cutting, the tape comes off with the film. It's much more stable than tabs if I take care to apply tape so that it holds the acrylic in strategic places. I usually cut small pieces of tape and stick them on the table before laying down the acrylic, which helps me find the critical spots by moving the spindle around.
    Feb 2008
    231
    I cut acrylic a lot. I just came in from the shop after cutting 32 pieces of it. I use a vac hold down system and tabs for letters and other smaller parts. The key I think for me is that with vac hold down I have very little vibration of the parent material as it is being cut and I use a 2 flute upcut 1/8 inch bit at 40 IPM. The smaller bit seems to introduce less cut force and does not tend to dislodge the parts from the tabs. Your tab size seems TOO big for me. I typically use tabs that are 30% of the thickness of the material and about .075 long. I also cut with compressed air blowing at the bit so that I have no melting of the material.
    Hope some of that helps.
    Scott
  1. how to optimize mastercam for lathe gang type
    By jhonyas in forum Mastercam
    Last Post: 06-12-2012, 05:09 PM
  2. Best way to optimize my program
    By jeffrey001 in forum Mastercam
    Last Post: 01-25-2012, 07:44 PM
  3. Checkout this cambam file. optimize?
    By diyengineer in forum CamBam
    Last Post: 10-04-2011, 10:10 AM
  4. optimize it
    By kesparate in forum Mastercam
    Last Post: 04-03-2009, 11:50 PM
  5. Software to optimize the layout of the factory
    By KAMPUZ in forum Uncategorised CAM Discussion
    Last Post: 05-27-2005, 08:47 PM
