586,345 active members*
3,273 visitors online*
Results 1 to 7 of 7
    Jun 2008
    11
    Mori Seiki SV-503 - MSG-501
    Hello,
    Need to change IP address for FTP...can't write change becuase of write protect parameter. For the life of me I can't remember where to turn that off. I have done it before. Should have documented it.
    Thanks in Advance
    Feb 2009
    6028
    Setting 61 input i believe. Been a while since ive been on a mapps1/2
    Jan 2007
    25
    Offset button, then 1 of the softkeys, set parameter 0 to 1
    Jun 2008
    11
    Hello,
    I pressed "Offset" hard key -> "Params" -> 61 -. changed from 0 to 1. Tried changing the IP address. Sill get the write-protect message.
    Jan 2007
    25
    Its the first parameter on the top. Called Enable write ore something like that. Be sure you are in mdi mode.
    Parameter 61 is for new fanuc i think!!
    So,
    Offset, settings, parameters write=1
    Feb 2009
    6028
    Miller-Mapps control...
    Smecher- change Mapps parameter lock. Same screen, make sure your in MDI. Not in offset-setting page like a standard fanuc. 61 is not the parameter, its the mapps screen. Says system parameter lock/unlock and Mapps parameter lock/unlock.
    Jun 2008
    11
    Hello,
    After fumbling though the menus I found the setting:
    "Settings" hard key -> 50 for "Settings" -> "NC Parameter Write" change from 0 to 1.
    Thanks everyone for your input, appreciate it.
  1. Mori Seiki MV-40M
    By MoraTradgnist in forum Mori Seiki Mills
    Last Post: 11-09-2021, 02:42 PM
  2. mori seiki
    By zavateandu in forum Fanuc
    Last Post: 03-29-2013, 06:14 AM
  3. Mori seiki TV 30
    By sanroyal.e in forum Mori Seiki Mills
    Last Post: 02-28-2012, 06:35 PM
  4. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
  5. MORI SEIKI SL1
    By tano in forum Mori Seiki lathes
    Last Post: 12-30-2009, 03:04 PM
