586,070 active members*
3,543 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Mazatrol with Mitsubishi drive and 61Y/35Y over regeneration alarm and estop.
    Oct 2012
    Got a mazak with Mitsubishi drives that when powered up after the night or weekend throws a 61Y over regeneration alarm and then a 35Y over regeneration alarm which throws it into estop. After multiple main power ons/offs and time (usually an hour or two), the alarm clears and is good to go for awhile. Anyone seen this or have a solution? Your help is greatly appreciated, thank you in advance.
    Attachment 227754
    Attachment 227756
    Jan 2011
    350
    How hard did you make your machine work? Did you go borderline max capacity? If you weren't trying to push anything, you might have to replace the corresponding drive or power unit that caused the alarm, since this type of problem would only get worse with time.
    Over regeneration means overheating of the regenerative resistor that you'll find in your unit. Check in your alarm book which drive does 35 and 61 correspond to.
    Oct 2012
    Thanks botha.y. This machine was never pushed very hard. It is a tool room machine only, so, probably only used 20% of it's available capacity. It's definitely the Y axis drive, and, it happens on start up only (Even if the main is not turned off but the machine control is). So, heat can't possbily be the answer, however, I have see some advice/documentation that it could be a voltage or current sag at startup. I have replaced drives years ago on this machine, but, installed Psytronic power conditioners and surge protectors and have not had a problem since. Any other thoughts? I will be checking voltage the next time the machine goes down and is not being utilized.
  1. Mitsubishi Spindle Drive Alarm
    By Antonio Arguijo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-08-2019, 10:36 AM
  2. Mazatrol with Mitsubishi drive and 61Y/35Y over regeneration alarm and estop.
    By Inputflangeman in forum Maintenance DIY Discussion
    Last Post: 03-10-2014, 09:48 PM
  3. cann't clear estop alarm after 4th was removed
    By dingo0722 in forum Haas Mills
    Last Post: 04-06-2012, 08:44 PM
  4. Mazak T32-6 alarm 37 over regeneration
    By Karsue in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-13-2012, 09:31 PM
  5. Mazatrol t-1 F estop fault
    By pmauldin in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-09-2011, 06:08 PM
