603,855 active members*
3,963 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Version 19 tip and tricks
    6855
    Post your Bobcad ver19 tip and tricks here!
    Jun 2003
    446
    Adding a hot key for UNDO
    TIP#1:
    To add a ctrl+Z do the following:
    1. Select the Special/NC CAM menu and then choose RECORD SCRIPT and then MENU CONFIGURATION from the sub-menu.
    2. Under Menu Type enter CAD.
    3. Under Number of Menu Levels check #2.
    4. Menu level 1 needs to be set to 1.
    5. Menu Level 2 needs to be set to 5.
    6. Key: Z (not the #2...use the letter Z)
    7. Check the Ctrl option and un-check Alt.
    8. Select EDIT and you should be good to go.
    CNC Dude
    Nov 2003
    49
    Pi in V19 scripts
    The function Pi is not defined in the V19 scripting language.
    A temporary work around is to add the following at the beginning of the script---
    Pi=3.14159265358979323846264338
    Poor planning on your part does NOT constitute an emergency on my part!
