603,813 active members*
3,901 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Linear Guide Rail Selection - sizing
    Mar 2012
    32
    I am designing a cnc mill for myself and my question is: how do you calculate the correct rail size given the size of the machine? Looking at the pdf from Hiwin it appears that you need to calculating dynamic, static and moment load ratings so really the question is how do you do that?
    Thanks, Ron.
    Jul 2018
    6841
    Re: Linear Guide Rail Selection - sizing
    Hello Ron - Firstly what size spindle or motor are you putting on the mill? Then you need to know the distance from the tool to the various rails to calculate the moments. From the moments you can calculate the loads then you look at the manufacturers specs and check the bearing meets these specs. If you get the detailed design manual from Hiwin they have worked examples for typical bearing arrangements. Cheers Peter S
    Jun 2011
    692
    It's usually the deflection that determines how big you need to go on a high-precision mill.
  1. Sizing Z axis linear rail
    By jevs in forum DIY CNC Router Table Machines
    Last Post: 02-10-2014, 08:50 AM
  2. Linear rail selection?
    By dlenardu in forum Vertical Mill, Lathe Project Log
    Last Post: 12-08-2010, 08:47 PM
  3. THK FBW/FBW2560R Linear Bearing Guide Slide Rail
    By BackyardWorkshop in forum DIY CNC Router Table Machines
    Last Post: 09-02-2010, 07:52 AM
  4. Need Help- Selection of balll screws and linear rail
    By Khalid in forum Linear and Rotary Motion
    Last Post: 06-17-2010, 08:11 PM
  5. Haas TL-x linear guide sizing - Please help!
    By dareposte in forum Haas Lathes
    Last Post: 09-07-2008, 08:33 AM
