603,785 active members*
17,756 visitors online*
    Mar 2014
    UPS INstallation
    I have 2 CNC lathes from MYDAY and electricity is a big problem in my place. Sudden interruptions causes multiple errors in PLC system & I ended up pulling out & re-install FANUC cards (just doing the reset). In this sense its so obvious that fluctuations affects the system.
    Is there any way I can install regular UPS in this machine? just to protect the system & not necessarily to continue the job. Atleast the UPS can give the machinist 5-10 mins power to perform proper shutdown. Please can you help how can I integrate the regular UPS. If you can send circuit to me i would appreciate it too much. It is not necessary to send me circuit of the same machine, I just want a guide on where to tap the UPS to protect the system from future breakage.
    Thank you very much...
    Jun 2004
    511
    Re: UPS INstallation
    My 2 Cents. It would not be possable to give the machinist 5-10 mins power to perform proper shutdown, due to the fact that the drives should shut down when the power goes wrong. To supply enough power to keep the entire machine on would cost way to much. Protecting the controller is thinkable as you would only need to UPS the power to the controler. Just look at the machines electrical prints an see what powers the control and change that circuit.
  1. jet's CNC kit installation
    By jetflatline in forum Charter Oak Automation Support Forum
    Last Post: 04-28-2016, 05:44 PM
  2. DRO installation
    By Bell 430 in forum Shopmaster/Shoptask
    Last Post: 04-02-2015, 03:15 PM
  3. VFD installation advice
    By Blakea1790 in forum Novakon
    Last Post: 11-10-2013, 01:29 AM
  4. ATC Installation
    By wbleeker in forum Tormach Personal CNC Mill
    Last Post: 02-14-2012, 03:41 PM
  5. E-Chain Installation
    By mcyr in forum DIY CNC Router Table Machines
    Last Post: 11-08-2007, 12:01 PM
