603,344 active members*
2,927 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Spindle Control Wiring help needed and mach3
    Mar 2013
    10
    So i had a sx3 that spindle driver board died. I replaced it with the more recent board from littlemachineshop and also purchased their spindle control board. All wired in (minus cnc control) it works great with the pins jumped. I have attached some images so you all know what im working with. Can someone help me with the pinouts and maybe mach3 setup, I can paypal you some $$ for a successful setup.
    Thanks in advance!
    Here is the wiring diagram from the littlemachineshop spindle control board
    Attachment 229862
    Here is the sx3 cnc control spindle pinout.
    Help me wire these 2 together so i can control the spindle with g-code
    May 2020
    Re: Spindle Control Wiring help needed and mach3
    I have a HSD 9 hp spindle and i want to connect to a simple VFD. Which pins do i connect, is it just the 4 biggest pins as the 3 phases and the forth pin2 as earth. Please help.
  1. Roland spindle wiring help needed please!
    By anthow in forum Spindles / VFD
    Last Post: 09-11-2013, 03:56 PM
  2. SX2/SC2 LMS Spindle Control Board Wiring (with pictures)
    By Nine8Six in forum Benchtop Machines
    Last Post: 08-24-2012, 05:38 PM
  3. Wiring VFD for control in MACH3
    By wormwood in forum Shopmaster/Shoptask
    Last Post: 03-27-2011, 03:42 AM
  4. VSD-A Spindle control in MACH3?
    By mkuivamaki in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-08-2008, 08:09 PM
  5. Spindle wiring help needed
    By jalessi in forum DIY CNC Router Table Machines
    Last Post: 01-15-2008, 05:02 AM
