603,371 active members*
4,011 visitors online*
Results 1 to 11 of 11
    Apr 2006
    92
    GOTO Z button
    I press this button to get my axis to jog to the home positions, either machine home or work offset home. IT always does the X and Y axis first, then the Z afterwards. How do I make it do the Z axis first? Then the X and Y. I find myself always having to jog the Z up so my tool wont hit anything before I hit the goto Z...
    35494
    What version are you using?
    Apr 2006
    92
    mach3 :P
    35494
    I meant what version of Mach3? The lockdown, or the latest release.
    Check the "use Safe Z" box in Config>Logic, and set the safe Z height on the settings page.
    Apr 2006
    92
    oh, its the lockdown 1.84. I tried looking in the huge pdf instructions for mach3 and also played with the settings but not luck yet. I'll try that. What should i have the safe Z at? is this the machine cords or the work offset cords?
    Apr 2006
    92
    Ok thanks I got it figured out, all good!!! your the master! I appreciate you always helping me on here.
    May 2009
    28
    logic>config
    Hi everyone!
    I use the trial version of MACH 3, Version R2.63 and i couldnt find there conig>logic. What I'm doing wrong? Where I must look for this function?(use safe z)
    35494
    Config>SafeZ?
    May 2009
    28
    Config>SafeZ?
    Yes Config>Safe Z settings> goto safe Z when stop pressed! When I'm seecting this option appears a messaeg(safe Z turned off, the command will be ignored)...I'm thinking where Is the SAFE Z button...
    In the latest version of mach 3 theres a safe z button, but in my mach 3 ver 2.63 it doesn't exist.
    35494
    Don't have that version installed. Is it in General Config? Or do you have Config>State?
    May 2009
    28
    It's right in config menu... There isn'nt state..
