603,897 active members*
5,777 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software > Stepper Motors stutter when jogging full speed at a regular pattern.
    Oct 2011
    4
    Hello all I am running a Chinese 6090 cnc and have developed a problem in when I move the machine in a direction this includes xyand z axis the velocity speed has and interrupted sound and pattern.
    I turned steppers by hand and no problems there so im concluding pc or mach3 issue .Driver test runs quite uneven .But machine has just developed this problem and was working ok.
    Any help would be greatly appreciated Thanks
    Mike
    Jul 2017
    350
    Your pc/os or parallel port or cable is the issue
    Ive got a pc eith windows 7 that will not pass mach3 driver test
    And when using this pc the movement is herky jerky and sounds horrible...once i change pc all is good
    Nov 2013
    5409
    Re: Stepper Motors stutter when jogging full speed at a regular pattern.
    the parallel port was really the only way for hobbyists to get into CNC years ago.....these days however there are some really good external motion
    controllers that are USB, or better still, Ethernet connected, and a lot of the stuttering/stalling that used to occur with parallel ports vanishes. I'm
    not saying that you can't get a parallel port to operate properly, but you will always be constrained that it has a fairly slow max pulse output
    pulse rate and will often result in stuttering motion at max speed.
    If you wish to investigate external motion controllers I would recommend an Ethernet SmoothStepper. I would disgregard all the crppy
    Chinese made boards, they seldom work as advertised and often rely on pirated Mach3 software, avoid like the plague.
    Craig
  1. Stepper Stutter
    By peregrin8r in forum Mach Software (ArtSoft software)
    Last Post: 03-04-2013, 12:18 AM
  2. Stepper motors stall, stutter with no load
    By stank in forum DIY CNC Router Table Machines
    Last Post: 09-26-2011, 01:48 PM
  3. Stepper stutter issues resolved
    By pencilneck in forum DIY CNC Router Table Machines
    Last Post: 10-14-2010, 01:13 PM
  4. Poor speed on stepper motors..
    By jaru-eri in forum Stepper Motors / Drives
    Last Post: 09-25-2009, 06:07 PM
  5. Stepper motors are still going at the incorrect speed. Need help with Mach3
    By Apples in forum Mach Software (ArtSoft software)
    Last Post: 12-24-2005, 12:29 AM
