603,795 active members*
3,080 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > RF-45 Clone Mill > IHC Charter Oak 12z conversion (RF-45 variant)
Results 1 to 18 of 18
    Mar 2012
    189
    My machine arrived today. I have already converted my G0704 mill using Hoss' plans through phase 1 (i.e stock + steppers) I found the setup to be lacking for machining steel in the way that I do and, well who am I kidding, I could afford a bigger mill and now I'm having at it. It was a bit drizzly today so hauling the crate in my open trailer to my house was concerning. I wasn't entirely sure if my plan to get it into the garage (hermit cave) was going to pan out, but luckily it did.
    Attachment 234726
    My trusty little orange tractor was of great help.
    Attachment 234728
    Fork attachment chained around the crate with the ramps under to support the weight.
    Attachment 234730
    Slid down perfectly.
    Attachment 234732
    I could just barely tip the crate back with the curl cylinder, but that made it easy to move.
    Not sure how I will be able to make room yet.
    Looks like it made it with no damage.
    -Jon
    Mar 2012
    189
    Re: IHC Charter Oak 12z conversion (RF-45 variant)
    I ordered my machine from charter oak because of the 4 places I emailed to check if they had machines in stock and what the shipping was, they were the only ones that replied. I figure if a business can't find the time to fire off an email to an individual whose money they want, I would have even less chance of getting a reply once they do have my money. FWIW.
    My design goals are:
    Convert this machine to Mach3 control to make prototype and 1 off steel parts.
    Machining IPM up to 10 ipm Rapids <200 ipm
    Avoid having to use coolant.
    Install economy one shot oiling system. ala cowanrg http://www.cnczone.com/forums/bencht...pm-30mv-4.html
    Use Chai's double nut c7 ball screws.
    Drive the axis with steppers.
    Provide for existing 4th axis or build a new one.
    -Jon
    Aug 2008
    187
    this makes a lot of sense, a new forum with 2 threads about ih/charter oak mills when there ALREADY is an ih/charter oak forum. LOL.
    Mar 2012
    189
    I dunno what to tell you, I thought the charter oak automation support forum was for support. The thread by ahab345009 got moved there and then back here. I hope all of the rf 45 theads strewn throughout get moved here. It's very frustrating trying to find the various builds right now especially since so many machines have different names. Bring on some more builds!
    -Jon
    Mar 2014
    17
    Quote Originally Posted by bjones View Post
    Yes, it actually does make a lot of sense. As maker said, the Charter Oak forum is more of a product support forum for Charter Oak's CNC mills, not a forum for RF-45 DIY CNC conversions in general. This sub-forum should be more for the latter. It was only by chance that the first two builds here happened be purchased through Charter Oak. It doesn't make much sense to categorized all these Chinese mills by their importer anyway since there are so many nearly identical models available through different importers. If the Zone were to do it that way there should be a Grizzly forum, a Harbor Freight forum, a Precision Matthews forum, a Bolton Tools forum, etc; but there isn't really, so it doesn't make sense to make all mills imported and purchased through Charter Oak go to a Charter Oak forum. I think it makes much more sense to categorize by the type of mill (RF-45, BF-30, X2, X3, etc). It seems they had already more or less started to do that in the Benchtop Machines forum and this sub-forum simply continues that trend.
    Mar 2014
    17
    Maker, good to see you got your mill in good order.
    Man, I need a tractor
    Aug 2008
    187
    news flash for you, ih and ih clones are not considered rf45's. rf45 clones are the smaller mills with approx 32x9 inch table sizes. ih mills are not just long table versions of rf45's, they are different in many ways which is why we have the term ih clones to describe them. fyi there are build threads on the ih/co forum that have nothing to do with getting support.
    Mar 2014
    17
    I'm quite aware of the differences which is why I went with the Charter Oak mill in the first place but it is still pretty similar overall. That's why they are usually labeled something like "IH - RF45" like in this thread:
    http://www.cnczone.com/forums/bencht...-bearings.html
    Or "IH Clone Build (Long Travel RF45)" on this thread:
    http://www.cnczone.com/forums/bencht...avel-rf45.html
    Or where Bob Warfield calls his mill an RF-45 here:
    http://www.cnczone.com/forums/bencht...-45-clone.html
    Bob also calls his machine an "Industrial Hobbies RF-45 milling machine" on his page here:
    CNC Conversion: RF-45 Milling Machine
    Here is a thread about an IH Clone mill where they discuss wanting to have an RF-45 only forum started such as this one. They obviously seem to classify the IH clone as in the same category as other RF-45s.
    http://www.cnczone.com/forums/bencht...rsion%20build=
    Here is a link to a page where Hoss lists the IH mill as the king of RF-45s on his RF-45 Clone mill page here:
    http://www.hossmachine.info/RF-45_Clone.html
    I could go on but I have better things to do today. I submit to you that the term "IH clone mill" is a sub-category of "RF-45 clone", not a whole new category. This forum should include all of them.
    Also....
    I know there are build threads on the Charter Oak forum and mine was moved there after I originally posted it in the Benchtop Machines forum as well. They are probably there because they were moved there too because this forum didn't exist yet. I didn't think it was a good place for my thread for the reasons I've already mentioned so I requested that they make an RF-45 clone forum in order to gather all the relevant builds in the same place. It seems the administrators agreed with me since they started this new forum. I think it will make finding info on RF-45 mill conversions much easier and I'm quite pleased that they did it.
    Mar 2012
    189
    I made the stand yesterday and got it painted during a break in the rain.
    The old "measure twice, cut once" only works if you remember the correct measurement.
    Attachment 235044
    My newish 7x12 bandsaw got a good test cutting all 8 pieces of 3" channel bundled.
    Attachment 235048
    Still cut straight though. Not too bad for a $650 saw with the stock blade.
    Attachment 235050
    I made the stand 28" square and 26" tall not including the leveling feet.
    Attachment 235052
    I made leveling feet from 3/4" bolts and 1/4" thick drops from a laser cutter.
    Attachment 235054
    This is just the sort of project I need the bigger mill for! G0704 turning an 11/16 drill to open up a 1/2" hole at .1 ipm. Without copious amount of cutting oil it would not have made it through.
    Attachment 235058
    On the stand next to the grizzly.
    -Jon
    Mar 2012
    189
    oops looks like something went wrong with the attachments.
    Attachment 235122
    Attachment 235124
    Attachment 235126
    Attachment 235128
    Attachment 235130
    Attachment 235132
    -Jon
    May 2008
    1185
    It is a bit hard to show the difference in size of the IH and the G0704. Many people just see the pictures and it is a world of difference.
    Having the 704 as a second mill still should save time on some projects, although for the money a used RF-31 is a great second mill and lets you drill in long stock easier than most.
    IH was having some problems in the past when Tommy was running the place. It looks like Paul is doing a much better job. Did you get your mill fast?
    youtube videos of the G0704 under the name arizonavideo99
    This shows the size differences pretty well.
    Hoss
    https://www.youtube.com/watch?v=e9yEEt4mLMg
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Mar 2012
    189
    Quote Originally Posted by arizonavideo View Post
    So far my experience would support that. As I mentioned earlier, Paul was the only of several possible vendors to even answer my inquiry for stock and shipping. He had 1 machine in stock. I paid for it on a Friday morning, and it arrived the following Thursday. I would consider that fast since I didn't even have time to move my junk to make room
    I'm certainly not giving up the 0704. I'm leaning towards giving it the Hoss' phase2 cnc + belt drive and build an enclosure to set it up for aluminum, in the event that I finish converting the 12z. I've been so busy making parts and now converting another mill (and hopefully my lathe) one of these days I will have to actually learn how to machine!
    Hoss' printed mill parts certainly helped visualize the size difference, but nothing like having the darn thing towering over you.
    Attachment 235254
    I'm 5'11 standing at the same focal length as the mill.
    -Jon
    Mar 2012
    189
    Well, I made a little headway. I was able to run a new 240 with neutral to the machine area and connect the motor to verify that it runs. I started on my electronics enclosure as well. I had an old automatic gate operator enclosure that I'm planning to use.
    Attachment 236208
    Just needs a little cleanup and some primer.
    Attachment 236210
    Attachment 236212
    Attachment 236214
    I am going to run the 240 into the cabinet for all 240 and 120v service. There should be plenty of room for a CPU, breakout board, drivers, power supply and room to spare if I eventually go with a vfd. I started making cutouts in the side where I will have a vent and the panel that will have motor outputs etc.
    I want to make a control panel this time and mount it to a robust swinging arm. This would go on the opposite side of the enclosure from the motor plugs.
    -Jon
    Mar 2012
    189
    I saved up enough for the next phase, ordering the ball screws. I took measurements from the machine (with a tape measure) and tried to find any other 45 conversions that listed what they used to create my plan. 25mm screws for all 3 axis is my thinking. The current screws are 1" so I know the 25mm will fit. I have my g0704 and access to 2 bridgeports for the saddle machining and any mods needed for the ball nuts. I have 7202B ac bearing pairs for one end of all 3 axis. Y and Z will be unsupported opposite and x will have 1 6202zz and optional snap ring. I am custom making all new end plates which I plan to secure with at least 4 screws like an industrial machine so I can align the end plate to the ball nut to prevent binding. I have drawn ends of the shafts 1/2 for easy fitting of coupler or pulley.
    Attachment 243516
    Attachment 243518
    Attachment 243520
    Warning, these drawings have not been tested on any of the machines listed. You are welcome to use, but do so at your own risk. I plan to update and repost once I have actually finished install with any changes plus end plates.
    Wow the preview for .pdf on this forum is terrible!
    -Jon
    Nov 2003
    287
    You really can't go by the 1" lead screws because the nuts have a smaller OD then a 25mm ball screw nut. To fit the 25mm nuts on the x and y you will have to machine or grind the saddle and table castings some. I have used 20mm on the X and y with minor machining of the castings and 25 mm on the Z. I see no benefit for the larger screw on the X and Y. Just my opinion.
    Mar 2012
    189
    I appreciate the input. Looks like you have converted a couple machines in this class. No problems with the 20mm screw flexing on the x axis on your md001?
    -Jon
    Nov 2003
    287
    No, flex is none issue. I don't have the Y axis supported on the end opposite the drive, just because of the short distance and lac of good mounting surface. Works just fine. The X axis is supported by bearing on end opposite drive. All ball screws have double nuts.
  1. ANXIETY - New Charter Oak Machine
    By Bob La Londe in forum Charter Oak Automation Support Forum
    Last Post: 07-24-2015, 06:51 PM
  2. Any plans form Charter Oak
    By LEARN in forum Charter Oak Automation Support Forum
    Last Post: 05-23-2014, 01:53 AM
  3. CHARTER OAK AUTOMATION SPECIAL
    By Charter Oak in forum News Announcements
    Last Post: 10-11-2013, 03:38 PM
  4. Charter Oak Automation
    By saabman in forum Charter Oak Automation Support Forum
    Last Post: 04-11-2013, 07:27 PM
  5. Is this a new X-2 variant?
    By digits in forum Benchtop Machines
    Last Post: 01-11-2008, 12:44 PM
