587,072 active members*
2,843 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Un hooking bar feed gives an error
    Jun 2013
    5
    Ok we have a Ganesh 5212tm lathe running fanuc oi-tc. Connected to it is the Ganesh V-65LE bar feeder. We want to disconnect the bar feed from the machine and use a manual air bar feeder. Problem is when we unplug the bar feed from the machine we get a bar feed alarm and the machine locks us out. So anyone know what wires to disconnect or if there is a parameter we can change to get this working?
    Jun 2004
    511
    Re: Un hooking bar feed gives an error
    That will depend on your ladder, and wiring diagram. Each machine builder does it to their print. If you have the print for the bar feeder you can make a dummy plug to let the machine see what ever inputs it needs.
    2932
    There may be a Keep Relay that tells the control there's a bar feeder attached... at least there is on the Doosan lathes I've worked on.
  1. DMC 60 H hi-dyn, 840D ~ MSG ... M00 causes error '600607: SPI-LK,feed stop'
    By brickie in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 03-05-2022, 09:08 PM
  2. Mach3 Feed Hold Error
    By MRM RCModels in forum Mach Mill
    Last Post: 05-26-2014, 10:11 PM
  3. No feed rate error in FeatureCam
    By drj_95018 in forum FeatureCAM CAD/CAM
    Last Post: 07-11-2011, 09:49 PM
  4. Tape Drip feed on Meldas50 - P32 Address Error
    By firechcken in forum DNC Problems and Solutions
    Last Post: 05-26-2008, 03:16 PM
  5. Hooking it all up
    By Dylwad in forum DeskCNC Controller Board
    Last Post: 05-02-2005, 06:38 AM
