603,939 active members*
3,192 visitors online*
Results 1 to 7 of 7
    Dec 2004
    783
    Hooking it all up
    Okay, Let me see if i have this right. Havent purchased the software/controller yet, but will be in the next week or so.
    Limit switches are all n/c and are all wired together in series, One side of the circuit goes to the limit terminal, where does the other side go? Ground or +5V?
    Same for the E-stop switch, ill assume this should be a n/c and hooked up like the limit switches?
    Should the E-stop switch send a signal to the software AND shut power off at the stepper power supply?
    Home switches should be n/c circuits, Should they end at ground, or +5V?
    Does the controller need +5V coming from the computer, or does it share the +5V with the Geckos?
    What about Pause and Start switches?
    Thanks for any help,
    Dylan
    Dec 2004
    783
    Okay,
    Figured out that all limit and home switches need to be grounded. I got my hands on 3 Omron optical switches and built a relay board to make them N/C switching ground. Accurate to .002mm according to Omron.
    Anyone know about the E-stop switch?
    This is the forum for the deskcnc controller isnt it? The lack of response/help is starting to scare me, I would really like to use the deskcnc system.....
    Thanks,
    Dylan
    Apr 2004
    39
    Dylan,
    Fred Smith (imserv) sometimes answers questions here, but you may have a better response here:
    http://www.imsrv.com/discus/messages...tml?1106497969
    I'm interested in this software/board as well, so will be curious to see how you make out.
    Good Luck!
    Mar 2003
    6855
    Quote Originally Posted by Dylwad
    Okay,
    Thanks,
    Dylan
    I get the feeling most people are using dos based control systems.
    Feb 2005
    Responses to Desk CNC
    Hi I agree the responses are quite slow. When i get my stuff i will put up anything i find out. It could be that the docs are very good. Try to remember that as this comes with its own software its probably more compatibl ewith its own equipment, and no i dont work for them, i just ordered their stuff.
    Have to say the hobby cnc guys were very rude, i asked about using UPS to the UK so i could track it and the basically said 'read the website', not very helpful.
    Dec 2004
    783
    Actually the responses at the imsrv forum are fast and helpfull.
    So far after a few bugs(mostly setup) the deskcnc software is very nice for the price.
    Dylan
    Nov 2004
    139
    Rude
    Quote Originally Posted by oneill222
    Yes I agrre, the hobbycnc ppl are rude...
  1. A little help hooking up Geckos please
    By foamcutter in forum Gecko Drives
    Last Post: 01-27-2010, 12:53 AM
  2. my new cheap servos
    By Dan S in forum Servo Motors / Drives
    Last Post: 02-07-2007, 08:57 PM
  3. Hooking up HobbyCNC board and motors to PC...
    By jdbaker in forum Hobbycnc (Products)
    Last Post: 06-06-2005, 07:10 PM
  4. Hooking up the xylotex board
    By yukonho in forum Xylotex
    Last Post: 01-17-2004, 06:30 AM
