586,077 active members*
3,797 visitors online*
Results 1 to 6 of 6
    Aug 2005
    9
    RFQ - on 1/2" mild steel plate
    I think this would be easy on a waterjet, but wouldn't be too hard on a CNC mill. I drew it in Sketchup (www.sketchup.com) and exported to DWG - which I've included. If you prefer the Sketchup files, I can upload them as well.
    I need 5 of each drawing shipped to 79226.
    Thanks, --B
    Attached Files Attached Files
    Jun 2006
    629
    Tolerances?
    "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
    Aug 2005
    9
    I'm not sure I know enough to specify. Surgical precision isn't necessary for the intended application - and if I had a mill big enough to do it on, I'd be happy with maybe +/- .005 or better if I could do it. The 4" center hole in the one plate and the 1 3/4" hole in the other plate might need to be fairly precise though, because it fits on an existing hub/spindle that is exactly 4" and 1 3/4" respectively. The plates are both 12"x12".
    Dec 2005
    25
    What is your timeframe on these?
    www.TOOLandFAB.com
    www.ControlledCutting.com
    Apr 2006
    1257
    Please upload the sketchup files.
    You won't get a good shaft fit with a waterjet or laser. Waterjet works well if you can ream the hole afterwards. Unless the waterjet is 5 axis, you will get taper on all the edges and holes.
    Waterjet can usually do +/- .010", +/-.005" is doable but harder.
    My $.02.
    -Jeff
