586,060 active members*
4,483 visitors online*
IndustryArena Forum > CAM Software > CamWorks > New CamWorks Virtual Machine Simulator
    Nov 2012
    7
    Has anyone set up a new Virtual Machine yet? I am currently about half way thru:banana:. I know there is little support yet, but it is new and the support will come. I have a few questions if someone out there has experemented with one.
    So far it looks great, and is a great enhansement to CamWorks with true machine simulation!! And best of all compared to Vericut its a fraction of the price!!!!
    Mar 2008
    111
    Re: New CamWorks Virtual Machine Simulator
    What do you need to know?
    Nov 2012
    7
    I am currently trying to build a horizontal bar mill, with Z and W axis. I did just get some support from CamWorks, but still have a few Questions. The M91 home positions is Z (the spindle) sucked all the way in, and W (the table) all the way away from the machine. I did not build my .STL files that way, i built them with the spindle, table, Y and everything positioned at zero. it seems I can ajust the axis parameters and the base offset to adjust it. but the big question is my "3d rotation of the table" that zero point is set at W-32". That is where it calculates the rotation from. how or where do i set that.
    Thanks for your reply.
    Mar 2008
    111
    My friend in the know says.... look at the Eurekascript pdf file SO FAR, Eureka uses $$BASEOFFSET, W parameter to update the rotary position
  1. Virtual Reality and 3D Printing – Beyond Virtual Prototyping
    By cncadmin in forum 3D Printer / 3D Scanner Discussion
    Last Post: 10-16-2013, 09:30 AM
  2. Using the Machine Simulator
    By willheg in forum CamWorks
    Last Post: 03-18-2013, 04:44 PM
  3. Tebis Simulator - Virtual Machines
    By ruthmann88 in forum Uncategorised CAM Discussion
    Last Post: 09-28-2012, 05:00 PM
  4. Running Camsoft in a virtual machine
    By HuFlungDung in forum CamSoft Products
    Last Post: 08-21-2008, 05:28 PM
  5. Virtual Machine Shop......
    By Moondog in forum DIY CNC Router Table Machines
    Last Post: 08-24-2004, 12:04 AM
