586,104 active members*
3,449 visitors online*
    Nov 2005
    244
    Exporting G code to dxf
    I am finding Ncplot a real go to tool for evaluating and working with .NC files.
    When I have my G code plotted out it shows the rotation axis with the cutting action correct. But when I export that out to .dxf format and open it all the lines are on top of each other and no longer shows a rotation. Attached are two screen shots to illustrate.
    Is there a way I can get a dxf file to look like the plotted 4 axis .Nc file?
    Thank You
    Attachment 237762
    May 2007
    37
    Re: Exporting G code to dxf
    Hi camtd,
    please have a look at the attached screenshots.
    Opened from the samples folder of NCPLOT the file Macro B Sample looping.nc
    Saved the plotted graphic in dxf format to disc.
    Opened with TURBOCAD and here it is. Perfect
    NCPLOT itself seems to handle z-values in dxf files all as zero or even suppresses them.
    Hope this helps !
    RIchard
    Aug 2003
    20
    I have the same exact problem with B backplotting i'd like to save in DXF... anyone would have an idea?
    ArchieF, Looping.nc sample file backplot is a 3 axis backplot on different planes (G17/G18/G19) and this is ok.
    May 2007
    37
    anorec,
    would you upload a sample file ?
    Richard
  1. Exporting G Code Without a Postprocessor
    By wimbley in forum SprutCAM
    Last Post: 01-27-2015, 02:34 AM
  2. Exporting a .stl file
    By camtd in forum EdgeCam
    Last Post: 09-17-2012, 09:39 AM
  3. Exporting 3D in .dxf
    By AiR_GuNNeR in forum Uncategorised CAD Discussion
    Last Post: 11-20-2010, 11:04 AM
  4. Help with exporting to dxf
    By CJdave in forum Solidworks
    Last Post: 04-20-2009, 04:22 PM
  5. Saving / Exporting as .dxf
    By harley4ever in forum Uncategorised CAD Discussion
    Last Post: 10-24-2008, 05:52 AM
