586,096 active members*
3,164 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > DynaCNC > Please Help! - DynaCNC 4000 Blowing Z Axis Fuses
    May 2014
    I have a very large DynaCNC table with a Z axis problem. As soon as I reset Mach 3, the control box kicks in, then out and blows the 10 amp mini auto style fuse. It just started doing this and happens as soon as the reset is pressed on Mach 3. Any ideas on what to check or how to go about troubleshooting would be greatly appreciated. Thanks in advance.
    Brian
    May 2007
    111
    Re: Please Help! - DynaCNC 4000 Blowing Z Axis Fuses
    try swapping gecko's between z and x or y and see if the problem follows the gecko.
  1. Keep blowing fuses
    By bujaman in forum Maintenance DIY Discussion
    Last Post: 01-29-2014, 07:26 PM
  2. Y-axis servo motor blowing fuses
    By crazeekev in forum Bridgeport / Hardinge Mills
    Last Post: 02-08-2009, 11:39 AM
  3. Blowing Z axis fuses on 6MB
    By moldmker in forum Fanuc
    Last Post: 08-30-2008, 05:34 AM
  4. X-Axis Blowing fuses
    By Thom45 in forum Commercial CNC Wood Routers
    Last Post: 02-21-2007, 08:33 PM
  5. Blowing the fuses
    By rocks101 in forum Hobbycnc (Products)
    Last Post: 02-26-2005, 10:00 AM
