587,019 active members*
5,817 visitors online*
    Apr 2007
    161
    Strange Problem?
    Hey I am having an issue and I don’t know what is wrong. I just finished my Joes 2006 cnc and just getting things moving.
    Basically when I use the pendant (Usb Shuttle Pro) to move the cnc around it moves great (250ipm on the X). When I load the roadrunner in mach3 and do a no contact run the machine sounds sickly mainly the X axis. What I mean by sickly is that I am not getting that normal high pitch, it is more of a low pitch. It seems like it doesn’t have enough power. I am only running the program at 60ipm. At 120ipm the X gets a bit jittery. It just doesn’t sound right.
    I thought I might have had a bad power supply since it would move fine one axis at a time fine but would sound like it was bogged down/low on power when all 3 axis are running. I swapped out the power supply with (2) 24v 6.5A switching power supplies. X got it’s own power supply. Didn’t make a difference.
    I am running out of ideas. Any help would be great.
    Machine Info / Settings
    Joes 2006 R-1
    (I have everything from Kelings 425oz Hybrid Kit)
    Motors: KL23H286-20-8B /nema 23 / 425oz / 8 – wire / 1.8 deg
    Drivers: KL-4030 / 3.0A / 24-40v / 1 – 1/64
    Controller: C10
    Power: 36v / 9.6A / Switching
    Screws: X&Y- Acme 5 start, 2 tpi Z – Acme 2 start, 5 tpi
    Software: Mach3
    Shuttle: Usb Shuttle Pro
    Router: Hitachi 2.25 Hp / 1800 watts
    Other: Cnc4pc -C47 / AC speed controller
    Settings / Other Info
    Motors are wired Bi-Polar Parallel, Drivers are set for 2.8A / 1/8 microstep
    Mach3 settings: X&Y set to 3200 steps / Z – 8000 steps, Accel about 1 second, Pulse is 5
    25,000Hz
    Apr 2007
    161
    Re: Strange Problem?
    Anyone heard of anything like this? Got any ideas?
    I have checked nearly everything I can think of.
    May 2014
    6
    What is problem you meet
    Sent from my RM-939_apac_prc_200 using Tapatalk
    Apr 2007
    161
    My machine doesn't sound right when I am running a program. It sounds like it is running low on power. It sounds fine when I am just jogging one axis at a time even at the same speed as the feed rate running in the program. I have checked everything that I can think of. I will have to make a video so you can hear what I am talking about.
  1. Strange DNC Problem
    By cbritton1978 in forum Okuma
    Last Post: 02-09-2018, 10:49 PM
  2. Strange LS problem
    By SSN Vet in forum Gecko Drives
    Last Post: 11-03-2013, 01:04 AM
  3. Strange LS problem
    By SSN Vet in forum Machines running Mach Software
    Last Post: 11-02-2013, 01:55 PM
  4. Strange X4+ problem
    By Mud in forum Syil Products
    Last Post: 09-24-2009, 03:08 AM
  5. Strange Problem
    By mrcosmos in forum Mach Software (ArtSoft software)
    Last Post: 08-17-2008, 01:55 PM
