587,722 active members*
3,537 visitors online*
Results 1 to 5 of 5
    Apr 2007
    9
    Strange Problem
    I don't even know how to begin with this one. Here is my current setup. Upstairs (in my nice comfy office with a nice comfy chair) I have my office computer. Said computer runs xp with an Athlon (x2) 3800, 2 gb ram, ati x1650 pro video card. Installed software Bobcad 21 (1st seat), Bobcad post processor Mach 3 Mill (06-06-08) and Mach 3 version 2.63. I have not configured Mach 3 for any machine, it is just as it came. I can import or draw my own in bob, turn it into gcode and view it in Mach 3 and everything is fine. Let's say that I open the bobcad cat with bob art and then save it as gcode. When I open the gcode in Mach 3 I see then bobcad cat. I then save it to a memory stick and take it downstairs. My cnc computer run xp with Intel core duo 2 ghz, 2 gb ram, nvidia 8600 gt video card. Installed is my second seat of Bobcad 21, same post processor and Mach 3 version 2.63. When I load the gcode in I see a wavy line instead of the bobcad cat. So far I haven't found anything that looks right.
    I have uninstalled Mach 3, deleted the folder, deleted the Mach 3 driver and used regclean to remove any traces of Mach 3 from the registry, reinstalled, rebooted before loading Mach 3 for the first time and reconfigured everything and it still does it. Here is my xml file.
    Attached Files Attached Files
    Mar 2003
    35538
    Can you post the g-code and a screenshot of the problem?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2007
    9
    Here are the shots and the gcode.
    Apr 2007
    9
    Well, I am kind of getting some where on this. My distance mode on the office computer is set for absolute and the cnc comp is set to incremental. When I switched the office comp to incremental it messed up too. Change it back things are perfect. That is the only setting on the general logic configuration I have changed. Seems like I remember reading something about CV somewhere. Both are set to CV.
    Mar 2003
    35538
    Set both machines to absolute mode (G90). Incremental is not commonly used.
    Gerry
  1. Strange problem ! BP II interact 4
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 08-28-2008, 03:48 PM
  2. Strange problem with HT 40
    By hell_pk in forum Fanuc
    Last Post: 04-29-2008, 11:23 AM
  3. CNC strange problem
    By huben_123 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-15-2008, 12:12 AM
  4. Strange G03 problem
    By sploo in forum Mach Mill
    Last Post: 11-15-2006, 12:24 AM
  5. strange motor problem
    By sp00k1e in forum CNC Machine Related Electronics
    Last Post: 03-24-2004, 12:46 AM
