586,036 active members*
3,628 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > milling offset bigger than milling insert radius
    Good evening
    I have the following problem:
    When I try to program a tool with an offset of -6,20 mm on a SF20 R5, then Tebis always gives the following message: ’ Offset component part surface invalid’
    Even if I give attributes to the surfaces, the same message comes up.
    When I build a SF20 R6,3 or take a SF32 R8, then the whole programming works.
    Can anybody help me out?
    Many thanks in advance
    Regards
    -domme-
    It is not possible to program bigger than a miller corner radius with a negative offset !!
    Unfortunately, I don’t know a trick to bypass this situation, apart from creating Offset surfaces and mill them with an grinding allowance of 0.
    <br /><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo--><!--coloro:#4169E1--><span style="color:#4169E1"><!--/coloro--><b>Alle sagten: Es geht nicht &#33;&#33;<br />Dann kam einer der dies nicht wusste, und tat es</b><!--colorc--></span><!--/colorc--><!--sizec--></span><!--/sizec--><br /><br /><!--coloro:#0000FF--><span style="color:#0000FF"><!--/coloro-->Tebis: CAM Programierung, Datenbank Verwaltung, PP-Programmierung, System Administration<br /><!--colorc--></span><!--/colorc--><!--coloro:#2E8B57--><span style="color:#2E8B57"><!--/coloro-->Heidenhain: iTNC530 Anwender, Cycle-Design, Kinematic Design, und sonstige PLC Spielereien . . . .<!--colorc--></span><!--/colorc--><br /><br />
