586,094 active members*
3,861 visitors online*
    Jul 2009
    28
    Hello guys
    We are working for a while now with WorkNc and we are not really satisfied.
    There is something that makes me especially sick and tired:
    We have a DMU125 P hi dyn with millplus controller and I would like to use a milling radius correction so that I can also use regrind end milling cutters.
    Does anybody know a possibility without having to change the wnc program all the time?
    Regards ele
    What do you change in the wnc? The postprocessor usually does that. If you have nobody for radius correction, then go and get esomebody.
    It’s free you have a service contract.
    It’s only a line that needs to be changed but as i said just call them and you problem is solved!
    <span style='font-size:8pt;line-height:100%'>Leistung allein genügt nicht.<br />Man muss auch jemanden finden,<br />der sie anerkennt</span>
    Jul 2009
    28
    Merci you!
