586,103 active members*
3,824 visitors online*
    Feb 2012
    Hello
    I have tried to extend the data base of the standard component parts in the equipment folder in TopSolid CAM without success. I copied a top file into that folder but I couldn’t call/see that file from the CAM...
    Can anybody help me out please!
    Kind regards
    Hello perry
    The whole standard component part topic is very extensive. If you want to extend it a lot then I would recommend to you to participate in an extra course as the catalogues structures and the build-up play a vital role. Here you have to consider a few important points for later additions and/or amendments:
    Create an own library:
    “tool/options”
    ..add under component part/ user library “
    Add component part/assemblies to the library:
    1.create/open Design document
    2.define component part ... (add to the main group)
    3.“ assembly group/ define component environment/edit standard template /save“  save standard template
    4.define Dialogmask with the desired structures
    5.close document, done!
    Regards
    Michi
