586,103 active members*
3,514 visitors online*
Thread: Margin
    Aug 2008
    26
    Hello
    Is it possible to convert a margin into a top-curve?
    And if it is, then how?
    The case is that I have to mill a lot of 2D contours and always have problems with it.
    Hi Iceman,
    I’ve been working with DEPO-Cam for 5 years, I would love to help you, but I don’t understand your problem.
    For example we get lettering as a top-curve, we convert it into a margin and then engrave the lettering along the margin.
    I’ve never needed to convert a margin back into a top-curve.
    Could you give more info, I’d like to help you then.
    Greetings
    Himbeerton
    Hello!
    It’s possible in the new version (Depocam V9.0). You can then use those curves for milling with radius correction. But you’ll have to set the function in PP-parameters on true therefore.
    Greetings
    Sammy
    thanks for great help,i need it too
