586,102 active members*
2,485 visitors online*
    Mar 2012
    8
    Hello everybody
    I am working with Pro/NC Wildfire 4 for 4 months now. Even though I have no experience with any CAM systems I cope quite well with Pro/NC.
    However I have a little problem now:
    I want to mill a thread. Generally that’s no problem but I really need a radius correction with this NC series. The help in Pro/E did not help me out.
    I appreciate any suggestions!
    Apr 2003
    284
    Hello
    If I remember correctly then you can change from CUTCOM to LEFT in the parameters.
    I think, you can select on the last rider normal approach/departure pathin the dialog where you can select the axis..
    Finished. How you should have at least the radius correction in the CL_DATA.
    What you PP does with it is a different story..
    No brain no pain&#33; <br><br>www.JackTools.Net
