586,089 active members*
3,800 visitors online*
    Hello guys
    I have a question about Hurco’s simultaneous machining. According to Hurco the pivoting should be given out directly like the following:
    The information comes directly from Hurco. If IJK is not used, then it could potentially come to collisions.
    G68.2 X0 Y0 Z0 I1. J0 K0 U0 V1. W0
    IJK = Vector new X-axis
    UVW = Vector new Y-axis
    However with simultaneous machining, the manual recommends the following:
    X-15.211 Y6.75 Z-10.954 I-.721575 J.63735 K.270397
    My questions:
    1. What is I,J,K with the simultaneous machining ? Is that a surface normal? The UVW is missing here - against the positioning instruction.
    2. Do you also emit the coordinated after the processing?
    3. Have you got an alternative example?
    Datentechnik Reitz GmbH &amp; Co. KG<br />Händler und Support von<br />Sprutcam, Eureka, Blechcenter, Vector<br />T:06461 / 7593437<br />F:06461 / 7593438<br />www.cnc-Technik.de<br />[email protected]
    Hello spurtcam,
    Here a few lines from hurco vmx30u with A and C, the video:
    http://www.youtube.com/user/cncolaf?.../6/-beeaWoZ6dE
    here the data : ( created with ESPRIT CAM)
    N0001 (PP Hurco VM U 5X)
    N0002 (last change 30.05.2011)
    N0003 (22.06.2011 09:41:42)
    N0004 G17 G75 G40 G71
    N0005 M31
    N0006 (TOOL LIST
    N0007 (T112=SFHPC8.0)
    N0008 (T12=SFHPC7.7)
    N0009 G00 G71 G90 T112 M06
    N0010 S8000 M03 M08
    N0011 (SFHPC8.0)
    N0013 G69
    N0014 M31
    N0015 M128 M13 M33
    N0016 G43.4Q0
    N0017 X-50. Y-100. Z50. I0 J0 K1.
    N0018 X-43.583 Y.903 I0 J0 K1.
    N0019 I-.991041 J-.133562 K0
    N0020 Z-13.51 I-.991041 J-.133562 K0
    N0021 (PRE-MILLING)
    N0022 G01 X-41.105 Y1.237 Z-13.51 I-.991041 J-.133562 K0 F1000
    N0023 X-41.075 Y1.024 Z-13.26 I-.991041 J-.133562 K0
    N0024 X-41.042 Y.798 Z-13.031 I-.991041 J-.133562 K0
    N0025 X-41.008 Y.56 Z-12.821 I-.991041 J-.133562 K0
    N0026 X-40.969 Y.292 Z-12.618 I-.991041 J-.133562 K0
    N0027 X-40.928 Y.017 Z-12.438 I-.991041 J-.133562 K0
    N0028 X-40.882 Y-.293 Z-12.266 I-.991041 J-.133562 K0
    N0029 X-40.829 Y-.627 Z-12.11 I-.991041 J-.133562 K0
    N0030 X-40.763 Y-1.013 Z-11.959 I-.991041 J-.133562 K0
    N0031 X-40.68 Y-1.413 Z-11.816 I-.991041 J-.133562 K0
    N0032 X-40.654 Y-1.507 Z-11.78 I-.991041 J-.133562 K0
    N0033 X-40.585 Y-1.781 Z-11.664 I-.991041 J-.133562 K0
    N0034 X-40.544 Y-2.003 Z-11.563 I-.991041 J-.133562 K0
    N0035 X-40.518 Y-2.211 Z-11.463 I-.991041 J-.133562 K0
    N0036 X-40.505 Y-2.418 Z-11.358 I-.991041 J-.133562 K0
    N0037 X-40.504 Y-2.624 Z-11.249 I-.991041 J-.133562 K0
    N0038 X-40.516 Y-2.826 Z-11.136 I-.991041 J-.133562 K0
    N0039 X-40.54 Y-3.026 Z-11.019 I-.991041 J-.133562 K0
    N0040 X-40.577 Y-3.221 Z-10.898 I-.991041 J-.133562 K0
    N0041 X-40.604 Y-3.355 Z-10.813 I-.990969 J-.134088 K0
    N0042 X-40.595 Y-3.394 Z-10.786 I-.990754 J-.135669 K0
    N0043 X-40.543 Y-3.47 Z-10.733 I-.990482 J-.137643 K0
    Best regards
    cnc-olaf
    Thank you for the program. But what does IJK mean?
    Is that the x coordinate, the surface normal or what is it?
    Normally the coordinates are given out with XYZ ABC.
    That is logical, but I just can’t understand these coordinates at all!
