603,795 active members*
2,944 visitors online*
Thread: Hurco BMC 24
    Sep 2009
    15
    Hello
    I had a hard disk failure.
    I installed the software to the new hard disk. Now everything is running again.
    I only have one question:
    How can I reactivate the options Rigid Tab( tapping without compensation chuck) and Ultipockets (milling with islands).
    Apparently one can only use the disks once.
    Both is called from the Dongle.
    Maybe somebody has some advice for me.
    May 2007
    672
    smile.gif Hi
    Yes its true- one usually plays back the options on the disk- this doesn’t work in your case.
    The only solution you have is contacting the service
    G. smile.gif thomas
