603,957 active members*
3,841 visitors online*
Results 1 to 7 of 7
    Aug 2008
    5
    Hello
    Does anybody have a machine parameter list for the machine Maho MH900C with cnc432 controller?
    At the moment I need the complete parameter list and I'd like to buy a service/parameter manual for this controller.
    Regards,
    Mikko
    Oct 2007
    123
    Hello Mikko
    sorry for the late answer.
    I’ve got them only in German :-(
    Best regards
    Mahoist
    [attachment=6204:MC_9_432.pdf]
    Attached Files Attached Files
    Jul 2008
    6
    Quote Originally Posted by mahoist View Post
    Hello Mikko
    Best regards
    Mahoist
    the file only is an index. is there anything else available?
    thanks
    Dec 2001
    5090
    Quote Originally Posted by FIELDSJJ View Post
    thanks
    Hello FIELDSJJ,
    first at all - welcome @ CNC-Arena
    What are you looking for in detail ? The file explains what functions any of the machine constants have ...
    <b>Gruß / Regards</b><br /><i><b>CNCFanatiker</b></i><br />AdminCrew<br /><br />Wenn wir immer das tun was wir können, dann bleiben wir immer das was wir sind.<br />If we always this act what we are able to do, then we always remain what we are.
    Apr 2017
    7
    someone has the machine parameters for machining center MAHOMAT cnc 432?
    thanks.
    Hi;
    I have a boehringer vdf 250 c with a cnc 32bt controller . During diagnostics one of my IO cards is detected and five no fault , but it gives all I and O are on 0 even if they are on 1 .
    I switched cards , the same probleme with another card at same position.
    Jun 2019
    Hi. Is it possible to set a soft start and a spindle stop somewhere in the parameters? (Continuous). I have a MAHO 600 with Philips 432. It has an Indramat A31 frequency converter. When it runs at about 1000 rpm. , and turn off the spindle, it stops immediately when it hits. Thanks for help.
