586,096 active members*
3,707 visitors online*
    Hello everybody,
    At the moment, I often have to mill burned holes for example a 324mm and a 180mm big while.
    How can I create a program where I can enter the diameter, the depth (in this case 40mm), the cut
    4 mm and the tube size of the drill. (would be 310mm/ 170).
    With circular pockets the program always starts
    in the middle which would take ages in my case.
    Control system 432/10
    With best regards
    Mischah
    Dec 2001
    5151
    Hello Mischah,
    Basically only over parameter programming.
    Have you ever been engaged with it? If no then you should do that.
    If you have an idea about the implementation and a few programming samples then show it and we can
    build something here together. What would give you a learning effect that you wouldn’t get if we give you the finished solution =)
    <b>Gruß / Regards</b><br /><i><b>CNCFanatiker</b></i><br />AdminCrew<br /><br />Wenn wir immer das tun was wir können, dann bleiben wir immer das was wir sind.<br />If we always this act what we are able to do, then we always remain what we are.
    Hello everybody,
    With best regards
    Mischah
    Hello just program the contour with 3 G3 sets: circle IN, full circle, circle OUT and it takes only 1 minute.
    Regards
