586,105 active members*
3,196 visitors online*
Thread: TOOL CALL
    Hi guys how are you doing?
    Control system iTNC 530 Software Nr.340491-03 SP9
    When I press TOOL CALL on the control system, then the soft keys come up and GOTO doesn’t work either.
    However I believe that at least GOTO works since the controller TNC 435.
    With the programming space, three soft keys come up when pressing TOOL CALL: tool no, tool name and select
    Who know from what software version it works or what MP is responsible for that?
    What button do I need to press
    Thank you a lot
    Dec 2001
    5151
    Hello Hans-Michael
    MP7483 is responsible for the determination of the tool names and numbers that can be used with a TOOL CALL or TOOL DEF.
    0 = Name and number allowed
    1 = only name allowed
    2 = only number allowed
    I think you can use tool names since the 426/430.
    GOTO button with the TOOL CAAL set- what should that do? Doesn’t say anything to me.coangry.gif
    The button is without any function- it’s only active after pressing the softkey ‘SELECT’
    The ‘’select’’ only exists since software version 340494-05, ( the current version is 340494-06-SP2)
    <b>Gruß / Regards</b><br /><i><b>CNCFanatiker</b></i><br />AdminCrew<br /><br />Wenn wir immer das tun was wir können, dann bleiben wir immer das was wir sind.<br />If we always this act what we are able to do, then we always remain what we are.
