603,767 active members*
2,858 visitors online*
Thread: USB
    Thumbs up
    Hello people,
    I received Sinu Train software from my educational institution, a 60hours version.
    Everything installed, everything super and it works. But under the programs I have only the NC button and one where stands DISK A. There’re more buttons in my school, for example, network and also one FOR USB (I need it strongly)!
    I’d like to transfer my files to the machine via USB. It would be great if someone could help!
    Thanks!
    Barthelmann@Siemens Guest
    Hello,
    There’s a tool MaschKonf.exe in the folder SI_Train in the install path. For example C:/SI_TRAIN. You can set the path for files there.
    First choose the appropriate machine and then path for files on off.
    There you can choose and mark softkeys and set the path to USB.
    Done.
    Regards
    Bernd
    Yep!
    Thanks a lot!!!! Everything works as it should!!!
    Now I can continue at home.
