586,103 active members*
3,776 visitors online*
    Guten Tag!
    I don't speak German so please excuse the English post...
    I have a 2008 Chevalier QP2040-L with a Siemens 810D Powerline Panel.
    Versions as follows:
    Shopmill 06.04.12.00,
    PCU20,
    Caldera DOS 7.03,
    6FC5450-GAY03-5AH0,
    System 06.05.37-CCU3E
    Can I add the facility to load/run programs from USB by plugging in a driverless Floppy emulator device which uses SDHC memory?
    These are what I have in mind http://hxc2001.free.fr/floppy_drive_emulator/
    I have opened the access hole on the side of the control panel and there is an unused Floppy Drive socket waiting to be used. It seems that all I need to do now is find the floppy power connector inside the panel. I know driverless is easiest to do as doesn't involve writing custom drivers. I don't know if this will work on Caldera DOS though. Has anyone done this before?
    Also, how difficult is it to update shopmill/hmi software & cycles to latest releases? Can a programmer achieve this or does it require a Siemens/Chevalier Technician?
    Any help appreciated,
    John
