586,119 active members*
3,609 visitors online*
    Hello everybody
    I am working on a Kern D20 CNC turning machine with Sinumerik 810T controller.
    The problem is that the subprogram doesn’t work anymore. Completely different coordinates are approached in the simulation – not the once that are in my program.
    I tried to process a wave ( 400mm long) with different diameters . Raw material 80mm, finished measure between 45mm and 75mm. I used a cycle that I got from the ‘support’ for the roughing.
    However measures of 200mm-80mm are being pre-roughed in the slope. The sub program runs correctly during the roughing process. I had to write the whole program in separate sentences.
    That worked but it’s not the way it should work when you have cycles.
    Funnily enough there were no problems with the roughing in the first tensioning.
    Regards
    hapo Guest
    When the simulation doesn’t show what you believe you programmed, then it’s not the machine’s or controller’s fault..
