586,105 active members*
3,301 visitors online*
    Hello
    Could anybody suggest a program that counts 10 or 100 units, then stops and when I press rest, it should start from scratch.
    I work at Alzmetall with sinumerik 840D special drilling 4stations and loader. A program with R parameter would be great.
    Oct 2005
    55
    Hello
    To make it easy just write a program where you call the machining program as a subprogram, then you’ll be able to set any repeat. You only have to delete M30 in this program. It also works with counters etc., but anyway works straightaway.
    Greetings from China
    Hello
    Could you make an example for me? It would be great!
