586,075 active members*
3,989 visitors online*
    Morning
    We have a CTX machine with Siemens 840D controller (controller Shopturn) and powered tools.
    We want to mill a square in the program, but the programs only gives out the reverse rotation.
    Does anybody know how to switch it to synchronisation??
    Many thanks in advance
    There are 2 possibilities depending on how you mill the square.
    If you mill e.g. over the “Tenoners milling cycle” simply set the “processing direction” to synchronisation in the program head.
    Or you have programmed a contour and used the “path milling cycle” the you have to change the path correction in the cycle and possibly set the processing direction to “backwards”
    Kind regards
