Ok this is a follow up from my previous post. I cut a part from a stock but didn't come out to the right thickness. That brought me to my next question, how to properly bring the stock to designed size?
Here is my process
1. designed a part in solidworks, let's say it's 0.2" thick
2. using a 0.5" thick stock bar to cut the piece
3. in Cam, i defined the stock to be 0.1" on top and 0.2 on bottom.
4. the stock is actually 0.496" thick
now, i don't really know how to proceed. should I mill 0.1" from both side of the stock, measure the exact stock thickness, and re-enter it in CAM, re-generate the toolpath, and cut the part?
Or should I define the stock to be 0.4" thick, then mill 0.05" from one side, measure the remaining thickness, say it's X" thick, and face the other side with calculated thickness as X" - 0.4" to bring the stock to exact 0.4" as defined.
i'm leaning more towards the latter as I don't have to re-define the stock in CAM and re-do the toolpath. pls advice...
Daz
