586,103 active members*
3,594 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > HERMLE UWF 1000: external emergency stop with reference
    Good day,
    I have added a second hand Hermle UWF 1000th into my machinery. Now I have the following problem:
     machine is started
     X, Y, Z reference points are approached
     When approaching the reference point on the y-axis, an external emergency stop is being triggered and the machine cannot proceed.
     If the machine is rebooted, the error occurs again.
     Within the start-up routine, the order of the axes was reversed as well. The problem again is the same (Y-axis).
    My question now: what can be the cause of the error and how can I fix the problem.
    Best regards
    René
    Hello
    Might be the scale of the Y axis
    &quot;Lache nie über die Dummheit der anderen. Sie ist Deine Chance.&quot;<br /><!--sizeo:1--><span style="font-size:8pt;line-height:100%"><!--/sizeo-->Winston Churchill<!--sizec--></span><!--/sizec-->
