586,036 active members*
3,657 visitors online*
    Hello guys
    I’ve got the following problem. I need cutting values, covering depth, feeding for 1.4301.
    Side milling cutter Du. 125 with solid carbide turnover boards.
    I have to mill a slot with the depth of 32mm.
    Thanks in advance and I hope that someone can help.
    Regards, Dimi
    Hello
    Try to get out by the manufacturer of the side milling cutter:
    1. whether it’s suitable for 1.4301
    2. if it is, then with what speed
    You’ll have to decide about the feeding depending on the covering depth
