603,370 active members*
3,589 visitors online*
    Mar 2005
    18
    wiring it all together
    hi guys
    I am building a 5'x3' cnc router for woodworking
    and i am thinking of buying this setup from homeshopcnc
    3 motors rh34-640
    Holding torque-Nm (oz/in) +/- 10% 4.6 (640)
    Rated voltage 2.3
    Rated current per phase (amps DC) 5.5
    Resistance (Ohms) +/- 10% 0.42
    Induction (mH) +/- 20% typical 3.5
    Motor length (mm) 80
    Rotor inertia (g-cm^2) 1400
    Weight (kg) 2.3
    $299.97
    800VA Toroidal Transformer (60 Hz)
    115 VAC or 230 VAC primaries; 48 VAC secondaries
    Makes a 68 Volt, 11.75 Amp power supply when rectified.
    Mounting hardware included. $85.00
    10,000 MFD, 125 VDC Mallory Capacitor
    Maximum surge 150 VDC $40.00
    Bridge Recifier
    250 Volts, 20 Amps $10.00
    G201 - Step Motor
    Microstepping motor drive
    7A, 80VDC 10-microstep drive
    Opto-isolated step / direction
    Mid-band resonance damping
    Silent 20kHz PWM switching
    No low-speed vibration
    my problem is i still need a interface board to go with this
    any sugestions?
    the geko drives to the motors I can get from geko but how the rest all wires together I 'm a little unsure ?
    what kind and size of wire I should use?
    is there a site I could go to help me build this part
    thanks for your help Russell
    Dec 2005
    3319
    What gage wire to use:
    http://www.cnczone.com/forums/showthread.php?t=17350
    http://www.cnczone.com/forums/showth...480#post136480
    When it comes to wiring the steppers, make sure the wire is properly shielded - ditto that for the PC to any BOB's that you are using.
    BOB's = break out boards
    Jun 2005
    38
    interface board
    Russell,
    Check out some of the board options at www.pmdx.com and www.cnc4pc.com A hole range of choices there.
    Rick LaLonde
    www.homeshopcnc.com
