586,594 active members*
2,734 visitors online*
Results 1 to 7 of 7
    Mar 2011
    27
    750 Serial spindle link error
    The machine is a star sr32 with fanuc 16tt control. About 2 weeks ago, the machine began to give this alarm while it was booting up.
    "750 Serial spindle link error" on HEAD 2.
    later on after 10 seconds or so, it also gives the following -
    401 X AXIS VREADY OFF -
    401 Y AXIS VREADY OFF
    401 Z AXIS VREADY OFF on head 1 and
    401 Z AXIS VREADY OFF on head 2.
    I was simply turning off the machine, and power supply and turning them on again and alarm was going away easily.
    But today, when i turn on the machine, the alarm condition became stable, whatever i did, i could not delete the alarm.
    It also gives 19 on the led display of the spindle amplifier module.
    I saw some advices the check optical cables? i do not know how and what to check..
    Alarm Codes 19 and 20
    The offset voltage of the phase U (alarm code 19) or phase V (alarm code
    20) current detection circuit is excessively high. A check is made when the
    power is turned on. If this alarm is issued, replace the SPM. If this alarm is issued
    immediately after the SPM control printed circuit board is replaced, check the
    plugging of the connectors between the power unit and SPM control printed
    circuit board. ??
    Anyone experienced before?
    Jan 2011
    350
    Re: 750 Serial spindle link error
    Try swapping spindle sensor, else try swapping cable, else might be the drive.
    Feb 2011
    640
    check contacts on external/main contactor too- had one that broke a spring on a starter contact, would boot intermittently due to sometimes single phasing if the contact didnt touch. dont rcall if it was alarm 19, but sounds familiar.
    you can use most cellphone cameras to 'look' into the fiber optic cables- look at the end, one fiber should be bright purple, plug back in, look at other end, should also have one bright purple light...if both dark, look during reboot, some time-out/shut off... usually if the IREDs are going bad, one will be very dim- if you see a dim one, follow the cable back and look into the socket- if brighter, your cable is damaged. Iphones(at least one buddies at work) wont see infrared, but most others do- you can look at the end of your tv remote to test
    I just fixed a high voltage spindle drive tonight on a 0-i, it was intermittrntly giving a serial link fault, and saying 'dc link fuse blown'. took the amp apart, there were two 100k ohm 2 watt resistors on the DC buss, one was noticeably dark- checked them and the 'new' looking one was wide open... replaced it and it came right up- this serial stuff has really been a thorn in my side lately...its great when it works, but stupid little things go wrong and it sends you on a wild goose chase...
    klarmmachining Guest
    Is this problem solved?
    Jan 2011
    350
    Quote Originally Posted by tc429 View Post
    Ah yes even if it's unlikely the problem you might as well check the three phase voltage as well as continuity about everywhere on your circuit up to the spindle motor as well as the DC link voltage. You should also unplug your motor and meg it just to be sure it's okay. Be careful with capacitor discharging so you do not get a deadly electrical shock from this.
    Cheers.
    Mar 2011
    27
    Yeah, the problem is solved. This is not something related to wiring or so. It was a U phase current transducer failure on the drive power card - not the control one - We took off the drive and removed everything. We gave 24 volts of electric and saw that it was still blinking number 19 alarm on led screen. There was not any possibity of using even a small current, so we directly removed the current transducer from the board. Gave 24 volts again and the alarm had gone. I bought a brand new one - lucky me hard to find a new one - and it works just fine now.
    Aug 2007
    51
    In my case, the 2 resistors R51 and R52 on the DC buss were open. The resistors are on the main board of the Spindle Amplifier (not on the communications board).
    Replace the 2 resistors at it might solve your problem. I've been searching for a solution all over the internet and couldn't find anything that worked, so now i decided that every time i solve a problem and fix something, i'll post it everywhere for anyone to see.
  1. spindle serial link error 750 Fanuc 21i
    By Abdul Haq in forum Fanuc
    Last Post: 07-13-2021, 03:09 PM
  2. spindle serial link error 750 Fanuc 21i-MB
    Last Post: 05-13-2008, 11:59 AM
  3. help!: spindle serial link error
    By emonje in forum Fanuc
    Last Post: 05-09-2008, 04:07 AM
  4. Alarm 408 Spindle Serial Link Start Fault
    By boricuajdm in forum Fanuc
    Last Post: 04-23-2007, 06:26 PM
  5. Alarm 408 Spindle Serial Link Start Fault
    Last Post: 04-21-2007, 05:19 PM
