587,633 active members*
3,202 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 18i- MA "Not Ready" on startup!
Results 1 to 8 of 8
    Mar 2014
    11
    Hello! We have Cincinati VMC 750 Machine with Fanuc 18i MA control(LCD mounted type).Few days back,when machine was started in morning (Push "On" button on control),booting takes place(i.e,files r transferred from FROM to DRAM) successfully.After booting,black screen comes out on which fanuc software No. is written and at the bottom of this screen,"Not Ready" is written(Control get stuck there). I have checked emergency switch(Only one is installed on Machine) and limit switches of X,Y,Z axes but they r working properly. When "Not Ready" screen is shown, "LED 1" and "LED 3" Green status LEDs situated on control back side(Unit rear view) r bright and they keep on bright.No red Alarm LED is ON.
    Kindly can anyone help me how to fix this problem.i shall be thankful ..
    Sep 2005
    Re: Fanuc 18i- MA "Not Ready" on startup!
    Oh Boy! I had the same problem. At first we thought it was the graphics card. In the end it ended up being the motherboard. To be more specific the communication part of the motherboard that tells it to go to the next part of the startup sequence. I had to replace my motherboard. Sorry to give you the bad news. I hope you have a better result.
    Mar 2014
    11
    99,kindly can u tell me wht exactly do u mean by motherboard?do u mean the electronic card on which status leds and alarm leds r mounted?can u tell its card no?Thankyou for ur earliest attention...
    Sep 2005
    Yes the main electronic board in which all the serial cables will be attached to it. The main cover should say 1 PSU. It should have a serial number similar to this A16B-3200-210/02B. Fanuc will repair or replace your board. It depends on how fast you need your machine up and running. I bought a refurbished board from them because I was not going to pay an extra $1000 for a new board. Before you remove anything BACK UP ALL OF YOUR MACHINE'S PARAMETERS, DIAGNOSTIC PARAMETERS, TIMERS, ETC....!!!!!!! I had a service tech come in and try to save mine but to no avail. Fortunately I had a backup but I was missing a few that the machine seller added in. It took a whole day to get it back to normal. Call a service tech to verify and maybe he'll be able salvage your parameters unless you have them on disk or hard copy then you're good. Unfortunately this fix is not cheap but it was the only way to get my machine up and running again.
    Mar 2014
    11
    99! do u have this same machine cincinatti sabre VMC 750 with fanuc control 18i MA ??or just this fanuc control on which problem occurred?
    Sep 2005
    I have a 2001 Femco kfv-40 with the Fanuc 18-m controller.
    Apr 2009
    1379
    If it is your motherboard, we may be able to help you. The problem can also be in a module. Where are you located?
    Aug 2014
    hello everyone.. May be blower can't work. So today I see it. And the other way; if you carried your machine please check your phase. I see that too..
  1. Replies: 13
    Last Post: 08-15-2018, 06:22 PM
  2. "Not Ready" on a Fanuc O-M Controller
    By daewooDmv3016 in forum Fanuc
    Last Post: 02-13-2013, 05:03 PM
  3. Fanuc spindle drive "not ready"
    By Pyretta-Blaze in forum Fanuc
    Last Post: 12-11-2012, 12:00 PM
  4. Fanuc 6m stays in "not ready" mode
    By hopcycle in forum Fanuc
    Last Post: 01-30-2009, 02:58 PM
  5. "Not Ready" at startup
    By christoph in forum DNC Problems and Solutions
    Last Post: 08-04-2007, 02:55 AM
