588,531 active members*
8,275 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Having issues with Gecko drive.....
    Jul 2014
    59
    Tell me what you guys think.
    I have finished my build and have been doing some movements with the trial version of Mach3. I burnt my G540 up a couple weeks ago (operator error) and just got it back from the repair shop. One issue I had both before and after the mishap deals with the Y Axis. I have attached everything and gotten good movement out of the machine.
    The problem arises 5 or so minutes after starting up. The Y Axis will move just fine initially and then simply quit. There are no faults on the drive. I have verified that it's not the motor by running the motor on a different axis port. I have verified the cables by switching those up. I can turn the drive off for a short period and when I re-energize it the Y will operate for a few minutes.
    When I sent the G540 back to get repaired I told them about this issue. I feel like it might be overheating. I'm not putting the drive in the enclosure until I'm sure everything is fine, so I've ruled out that the entire unit is getting hot.
    Any ideas?
    Re: Having issues with Gecko drive.....
    It should have a heatsink or fan blowing on it.
    Jul 2014
    59
    I currently have it exposed. I didn't imagine it would heat it that quick to shut it down. I assumed that it was overheating but the timing was tricking me. It just seemed too quick. I have a heat sink that I'm going to install.
    You think it's heating up that fast and causing it to quit?
    Just a guess, but maybe.
  1. KL34-180-90 with Gecko G320x Tunning issues
    By MecAut in forum Automation Technology Products
    Last Post: 03-08-2013, 07:05 AM
  2. gecko 320x maxon encoder issues
    By airdamien in forum Gecko Drives
    Last Post: 07-01-2012, 03:03 PM
  3. Re Gecko Wiring Issues
    By SPEEDRE in forum Gecko Drives
    Last Post: 06-01-2008, 03:54 AM
  4. ims drive issues
    By austin.mn in forum Stepper Motors / Drives
    Last Post: 09-08-2007, 07:36 AM
  5. Gecko 201 issues
    By massajamesb in forum Gecko Drives
    Last Post: 08-25-2006, 02:54 PM
