Good morning sirs.
I'm getting this alarm on the machine while the Z axis is working or is stopped, and in different positions. This is a simple axis with motor encoder, no scale, and works in vertical position.
The diagnosis 300 is between 1 to 3 while the axis stops ant the parameter for the following error is 5000 ( I d'nt renember the number now). It seems that is not a mechanical problem
So my problem is that in the Fanuc manual I have the following instructions to solve the problem: "Follow the procedure",and no more.
Some body knows??
Thanks in advanced
